Forum >AS7341 11-Channel Light Sensor for sky color ? + Audio DAC SHIM ??
GravityHow to select
userHead Julien.Bayle 2024-04-13 07:45:17 821 Views0 Replies
Hi there,
This is a two questions in one.
At first, I'd like to know if I can AS7341 11-Channel Light Sensor can be a nice solution for the measuring the color of the sky ? ambient light.
Is is possible to NOT use the embedded two light ?
Then, I'd like to use it with a Raspberry Pi, and possibly a Audio DAC SHIM.
This latter uses uses GPIO 18, 19, and 21 (as well as 5v and various Grounds)
Would it be a problem to combine both, pin connectors wise ?
Best regards,
Julien
