Forum >DFplayer mini with TPA3138D2
How to select
userHead Silvan2468 2024-04-17 13:17:23 475 Views0 Replies
Hello
I will do a mp3-speaker for rc models with the dfplayer mini. And amplify it's signal(s) with an amplifier TPA3138D2 from Texas Instruments.
As I have read at the TI forum, differential signals to the TPA3138 are better for good sound quality than one direct line signal.
So my question is:
Shall I connect DACR as direct line to the positive differential input of the TPA3138 and connect the negative differential input to groun, or shall I connect SPK1 to the positive input of the differential input from the TPA3138 and SPK2 to the negative differential input?
According to TI-datasheet the differential inputs withstands -0.3 … 5.5V.
But like this, I would connect an already amplified signal to an amplifier what I am not sure if it is the way I should do or even will destroy the TPA3138 or the dfplayer mini.
Thanks for an answer.
