Forum >Checking out new Latte-Panda Mu boards
General LattePanda
userHead David.Witten 2024-04-19 07:48:52 631 Views2 Replies
I have received two Latte Panda Mu kits.  I ordered one with the large carrier board including the fan-based heat sink and accessories, The other with the smaller carrier and both passive heat sinks.  These boards offer me a lot of possibilities for development of remote sensor networks wit moderate local processing power.
The only negatives so far are that I can't figure how the laser-cut acrylic mini-case is meant to fit using the heat sinks (Small support board) and I do not seem to have received a power button to put on the large carrier board.  Any suggestions?
Dave
2024-04-25 02:21:50
The laser-cut acrylic is installed between the PCB and the bottom plate so that the bottom plate will not crush the sodering joints when tightening the screws.
I had the same confusion when I unboxed mine.
userHeadPic xingzhao.zhu
2024-04-20 19:56:12
Hello,  I'm wondering if there's an I/O shield offered with the full-function carrier board?  After all, it is the mini-ITX form factor.  It would make using it with an ITX case more convenient. :)
userHeadPic Rick.Downs
