Forum >Raspberry Pi4B Damaged Vs - DFR0494 UPS
General Raspberry Pi
userHead Sylvain.Marcelino 2024-04-20 04:11:17 590 Views0 Replies
Dear all,
I was using a Raspberry Pi4B and a DFR0494 UPS, but I made a mistake and powered the Raspberry through the USB-C port instead of the micro-USB port of the UPS. The result is that now the Raspberry does not boot, but the red Power LED is On, and the green LED is blinking at a very high frequency (not normal…).
I've tested the UPS with a second Raspberry and in this case, everything works fine.
Is there something I could do to save the damaged raspberry?
Thank you in advance for your help.
