I CAN ID ONLY ONE APRIL TAG. WHAT AM I DOING WRONG.
I am attempting to use Tag Recognition on the Huskylens. I aim the camera at an image containing multiple April Tags (an image on a computer screen).
The Huskeylens EASILY sees multiple April Tags in the image. A square appears outside each tag and there is a cross-hairs at the middle of the Huskylens monitor.
I move the cross-hairs to one of the April Tags and press the “learn” button. The Huskylens properly identifies that April Tag as “ID1”.
Here is my problem. I expect the cross-hairs to reappear so I can move to a second April Tag and press the “learn” button to identify that tag as “ID2”, etc, etc, etc.
Instead after the first tag is learned, and I press the “learn” button to id a second tag, the display says “Click again to forget”.
WHAT AM I DOING WRONG ???!!!
Never mind. I found the answer to my question in this document.
HuskyLens WIKI Document.pdf - GitHub
GitHub
https://raw.githubusercontent.com › SEN0305 › res
HuskyLens is an easy-to-use AI machine vision sensor with 6 built-in functions: face recognition, object tracking, object recognition, line following, color ...
41 pages
