Forum >5.8GHz Microwave Radar Module SKU:SEN0521 can detect trougth plastics? 100mm methacrylate for ex.
userHead Ibiltari 2024-04-23 03:31:04 425 Views2 Replies
Hi, we would like to hide the sensor  behind a metacrilate floor of about 100mm, made it point upwards and be able to detect when someone stands above the sensor. Should it work for this application? Thanlks
2024-04-25 23:24:51
Theoretically 5.8GHz millimetre waves can penetrate thin plastic.
In fact, the penetration should be about the same as the 5GHz of your home WiFi.
But I'd still recommend you get a SEN0521 for testing.
userHeadPic Yeez_B
