Forum >DFPlayer loop sound file setting using ADKey
userHead noo.para 2024-04-23 12:47:12 764 Views0 Replies
Can the DFPlayer be programmed to play a sound file in a loop without using UART by using the ADKey options?
It looks like if a 51K resistor is connected to ADKey to ground that it will play a sound file when the unit is powered on.  Is that correct?
