Forum >EMG-sensor Dc motor encoder. I'M TRYING TO CONTROL A DC MOTOR WITH ENCODER
TroubleshootingGravity
userHead JOEY.SOUSA 2024-05-14 15:54:41 684 Views6 Replies
Gravity: Analog EMG Sensor by OYMotion
SKU:SEN0240 Brand:DFRobot.
HEY. I WOULD LIKE HELP. I'M TRYING TO CONTROL A DC MOTOR WITH ENCODER. COULD SOMEONE HELP. PLEASE
Ícone "Verificada pela comunidade"
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "EMGFilters.h"
#define SensorInputPin A1   //sensor input pin number   SensorInputPin
//int sensorPin1 = A1
unsigned long threshold = 600;  // threshold: Relaxed baseline values.(threshold=0:in the calibration process)
unsigned long EMG_num = 0;      // EMG_num: The number of statistical signals
bool bandera=false;
EMGFilters myFilter;
  Set the input frequency.
  The filters work only with fixed sample frequency of
  `SAMPLE_FREQ_500HZ` or `SAMPLE_FREQ_1000HZ`.
  Inputs at other sample rates will bypass
SAMPLE_FREQUENCY sampleRate = SAMPLE_FREQ_500HZ;
  Set the frequency of power line hum to filter out.
  For countries with 60Hz power line, change to "NOTCH_FREQ_60HZ"
NOTCH_FREQUENCY humFreq = NOTCH_FREQ_50HZ;
int encoder0PinA = 6;  //0
int encoder0PinB = 7;  //1
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n0 = LOW;
long pos0 = 0;
int encoder1PinA = 6;
int encoder1PinB = 7;
int encoder1Pos = 0;
int encoder1PinALast = LOW;
int n1 = LOW;
long pos1 = 0;
int encoderPinALastR = 0;
int encoderPosR = 0;
unsigned long serialData;
int inbyte;
int digitalState;
int pinNumber;
int analogRate;
int mot5p = 9;       // Motor 5
int mot5m = 8;
int mot6p = 3;       // Motor 6
int mot6m = 2;
int sensorValue1 = 0;  // variable to store the value coming from the sensor
int sensorValue2 = 0;
int sensorValue3 = 0;
int rotateVal4;
int rotateVal5;
void setup(){
  myFilter.init(sampleRate, humFreq, true, true, true);
  Serial.begin(115200);
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
  pinMode(encoder1PinA, INPUT);
  pinMode(encoder1PinB, INPUT);
void loop(){
  int data = analogRead(SensorInputPin);
  int dataAfterFilter = myFilter.update(data);  // filter processing
  int envelope = sq(dataAfterFilter);   //Get envelope by squaring the input
  envelope = (envelope > threshold) ? envelope : 0;    // The data set below the base value is set to 0, indicating that it is in a relaxed state
  /* if threshold=0,explain the status it is in the calibration process,the code bollow not run.
     if get EMG singal,number++ and print
  if (threshold > 0)
        serialRead();
        rotateVal4 = serialData;
        if (pos0>rotateVal4){
          Stop(mot6p, mot6m);
        else{
          forward(mot5p, mot5m);
          Read(n0, encoder0PinA, encoder0PinB, encoder0Pos);
        serialRead();
        rotateVal5 = serialData;
        if (pos0>rotateVal5){
          Stop(mot5p, mot5m);
        else{
          forward(mot6p, mot6m);
          Read(n1, encoder1PinA, encoder1PinB, encoder1Pos);
    Serial.print (encoderPosR);
    Serial.print ("\n");
long getSerial()
  serialData = 0;
  while (inbyte != '/')
    inbyte = Serial.read();
    if (inbyte > 0 && inbyte != '/')
      serialData = serialData * 10 + inbyte - '0';
      Serial.println(serialData);
  inbyte = 0;
  return serialData;
long serialRead()
  serialData = 0;
  inbyte = 0;
  return serialData;
void forward(int x, int y) {
  digitalWrite(x, LOW);
  //digitalWrite(AIN_2, HIGH);
  analogWrite(y, 93);
void reverse(int x, int y) {
  //digitalWrite(AIN_1, HIGH);
  analogWrite(x, 93);
  digitalWrite(y, LOW);
void Stop(int x, int y) {
void Read(int n, int encoderPinA, int encoderPinB, int encoderPos){
 // encoderPosR = encoderPos;
  n = digitalRead(encoderPinA);
  if ((encoderPinALastR == LOW) && (n == HIGH)) {
    if (digitalRead(encoderPinB) == LOW) {
      encoderPosR--;
    } else {
      encoderPosR++;
    pos0 = encoderPosR;
    encoderPos = encoderPosR;
  encoderPinALastR = n;
   /*if get EMG signal,return 1;
int getEMGCount(int gforce_envelope)
  static long integralData = 0;
  static long integralDataEve = 0;
  static bool remainFlag = false;
  static unsigned long timeMillis = 0;
  static unsigned long timeBeginzero = 0;
  static long fistNum = 0;
  static int  TimeStandard = 200;
    The integral is processed to continuously add the signal value
    and compare the integral value of the previous sampling to determine whether the signal is continuous
  integralDataEve = integralData;
  integralData += gforce_envelope;
    If the integral is constant, and it doesn't equal 0, then the time is recorded;
    If the value of the integral starts to change again, the remainflag is true, and the time record will be re-entered next time
  if ((integralDataEve == integralData) && (integralDataEve != 0))
    timeMillis = millis();
    if (remainFlag)
      timeBeginzero = timeMillis;
      remainFlag = false;
      return 0;
    /* If the integral value exceeds 200 ms, the integral value is clear 0,return that get EMG signal */
    if ((timeMillis - timeBeginzero) > TimeStandard)
      integralDataEve = integralData = 0;
      return 1;
    return 0;
  else {
    remainFlag = true;
    return 0;
2024-05-14 16:45:30
userHeadPic JOEY.SOUSA
2024-05-14 16:44:40
2024-05-14 16:41:22
I would like help programming this movement in the video
JOEY.SOUSA wrote:
2024-05-14 16:46:17
2024-05-14 16:41:11
JOEY.SOUSA wrote:
2024-05-14 16:43:03
