Forum >SIM7600CE-T 4G(LTE) Shield - Does it work in Korea
Hi everyone,
I need to find a 4G module for an Arduino project. I've found the DFRobot SIM7600CE-T 4G(LTE) Shield.
However, my project will be used in Korea and I would like to be sure that the shield will be compatible with 4G network in Korea.
On the wiki page, I've found the list of support network:
-TDD-LTE B38/B39/B40/B41-FDD-LTE B1/B3/B8-TD-SCDMA B34/B39-WCDMA/HSDPA/HSPA+ B1/B8-CDMA 1X/EVDO BC0-GSM/GPRS/EDGE 900/1800 MHz
Even with some researches I haven't been able to know if the module is compatible with Korea.
Thank you for your help!
PE
