Forum >TEL0168 trying to configure as an ibeacon device
userHead jaf7034@gmail.com 2024-05-23 11:03:01 2978 Views1 Replies
Hello all,
I'm trying to configure and burn the TEL0168 beacon as an ibeacon configuration. I get the following error when I try to burn the configuration. When I select run in ram I don't see this error. I've attached a PDF of screen captures of the configuration I'm trying to use. I've also attached the saved configuration file that I've renamed from .cfg to .txt. Any help would be appreciated.
icon TEL0168ConfigFiles.zip 93KB Download(0)
2024-05-29 08:32:45
This is the 2nd request for help. I need to know the steps to configure the TEL0168 beacon as an ibeacon device.
userHeadPic jaf7034@gmail.com
