Forum >Gravity: IO Sensor Shield For Arduino Mega Due
https://www.dfrobot.com/product-560.html
so im curious and cannot find the definite answer.
how do you wire the mico sd card? is it already wired?
how to i call the correct 'pins' to write my data to micro sd?
2018-01-04 22:28:50 The pins on SD socket is connected to SCK, MOSI, MISO, SS pins on Mega, you can use the pins directly.
robert.chen
