Forum >DFR1117 ESP32-C6 serial monitor do not connect
userHead Gimont31 2024-05-28 10:05:47 612 Views3 Replies
Hello
I use the DFR1117 beetle ESP32-C6  arduino IDE2.3.2  board manager ESP32 3.0.0rc3
I did follow all steps given here for first time use
 https://wiki.dfrobot.com/SKU_DFR1117_Beetle_
ESP32_C6#target_7
I get this msg: A fatal error occurred: Failed to connect to ESP32-C6: No serial data received.
after hold down boot button and press reset , upload, then  I push reset again, the led is blinking, ( code uploaded) but the port COM1 is still unavailable…
I saw same issue in other post but, does not work for me…
2024-05-31 01:31:19
Yes, I also replied to you on another Topic. Failure to upload is usually a problem with the USB cable or port.
userHeadPic Yeez_B
2024-05-29 15:02:59
Sorry for inconveneience, problem fixed, this was due to the USB -C cable, power cable only…
May be this is good to know for newbies  to double check cables!!!!!
userHeadPic Gimont31
2024-05-29 06:32:27
I also tried on IDE1.8.19 ( installed from scratch). With this IDE the status at the bottom  says  COM1 disabled…
