Forum >SEN0259 Broken Connector
userHead Batu Cem.Özyurt 2024-06-03 05:58:36 811 Views1 Replies
I have been using the TF Mini-S Lidar (SEN0259) product for a time and broke off the wire-to-pcb connector on it. For now I have soldered on normal pins but it can only be a temporary solution, is it possible to find the connector on market or at least some details on the pitches so that I can mount a similar connector? It is not easy to say if it has 0.8mm, 1mm or 1.25mm pitch.
2024-06-04 10:02:35
You can consider creating a custom connector solution. This can involve designing and 3D printing a new connector housing, or even soldering wires directly to the board if necessary.
userHeadPic lia.ifat
