Forum >NOT WORKING: Underwater Submarine Ultrasonic Sensor Module Probe IP68 UART
TroubleshootingArduino
userHead mfederle 2024-06-05 12:51:34 700 Views2 Replies
I recently purchased the UART IP68 and am trying to run it. I have copied the code exactly from the wiki page but have no luck. I am getting no output on my serial monitor. Do you have any suggestions or do you believe this is a malfunction with the device itself?
Please let me know!
Thanks!
2024-06-08 09:25:26
Plz check for a baud rate mismatch.
userHeadPic lia.ifat
2024-06-07 20:17:08
hi, have did u try it with arduino? because it worked fine for me. maybe further explanation on your problem? maybe check the baud rate, its set to 115200.
userHeadPic ham
