Forum >Lark flashing RED after trying Communication to UART in Config.txt file
userHead Tavdog 2024-06-09 18:51:06 582 Views8 Replies
I can't seem to turn on UART mode for the Lark weather station.  When I change the first line in the Config.txt file from I2C to UART it just flashes red at me on reboot.
2025-01-12 13:16:37
I tried this technique where you reformat the USB drive.
It doesn't seem to work.   My Lark continues to show the yellow light for 1 second.   But the mount USB drive does not contain any new files, let alone a new config file.
What should I do now ?  I would very much like to get this thing working again ?
userHeadPic joe.blow
2024-06-19 02:07:22
Also, apparently it needs to be uart in the config file not UART for .
userHeadPic Tavdog
R2D2C3PO wrote:
Connect the Lark to the computer, open the USB drive that pops up on the computer, and open Config.txt. Change the first line from I2C to UART, Both uppercase and lowercase UART are acceptable.
2024-06-22 06:58:57
2024-06-19 02:06:13
How can I factory reset ?  The documentation on this device is horrible.
userHeadPic Tavdog
R2D2C3PO wrote: 2024-06-22 07:00:16 1 Replies
2024-06-10 07:41:58
If possible, try to factory reset the device and see if the problem solves.
userHeadPic lia.ifat
2024-06-19 02:06:36
Xiao wrote:
When you modify the config file and restart Lark, if the yellow light turns off and the red light turns on, it means that incorrect configuration information was written to the config file. In this case, you need to do the following: format Lark's USB drive, then power it off. Power it back on and wait for the yellow light to turn off, then power it off and on again. At this point, you will see a brand new config file on Lark's USB drive.
2024-06-22 14:59:56
