Forum >Gravity TDs and temperature sensor
TroubleshootingGravity
userHead zamanbujang77@gmail.com 2024-06-11 05:44:40 220 Views2 Replies
My temperature code complete with TDs not working
2025-02-25 14:50:59
@Reyson How are you measuring the output?  How are your forcing the maximum voltage out of the part?
userHeadPic sean.catheroy
2025-02-25 08:43:43
why is my TDS sensor maximum ouput voltage is only 1.5 volts, but the data sheet says 2.3V
userHeadPic Reyson.Pua
