Forum >TEL0134
TEL0134
userHead Lukas.Vizina 2024-06-19 09:18:29 408 Views2 Replies
I bought the TEL0134 and I cant find any english datasheet and command set, Can you send me one?
Wish best regards
Thanks Lukas Vizina
2024-06-19 09:56:55
Try the following and please tell us if they work.
Address: Typically, the I2C address for TEL0134 is 0x40.Commands:Measure Temperature: 0xE3Measure Humidity: 0xE5Read Temperature from Previous Measurement: 0xE0Write User Register: 0xE6Read User Register: 0xE7Soft Reset: 0xFE
userHeadPic lia.ifat
lia.ifat wrote:
Here I got the product specs in English: https://www.makerfabs.com/desfile/files/a9g_product_specification.pdf
Here is an AT command list: https://ai-thinker-open.github.io/GPRS-AT/A9_A9G/doc/AT-Command-Set.html
For GSM and GPRS communication only, you can also use SIM900A instead.
https://www.theengineeringprojects.com/2022/11/sending-sms-call-with-gsm-module-and-raspberry-pi-4.html
2024-06-19 10:05:56
