Forum >Replacement motors for Devastator Tank Chasis
General Robotics
userHead Keith.Burton 2024-06-20 00:24:43 550 Views4 Replies
I would like to replace the original motors with Metal Gear Motors with encoders attached.
Is the Metal DC Geared Motor w/Encoder - 6V 300RPM 3.6Kg.cm (FIT0520) a direct fit,  if not what would you recommend?
2024-06-30 00:12:25
Can you tell me the spec of the original motor please
userHeadPic Keith.Burton
2024-06-21 08:14:43
Check the size, mounting hole positions, and overall dimensions of the FIT0520 motor against your current motor.If the FIT0520 is not a direct fit, consider motors from reputable suppliers.
userHeadPic lia.ifat
Keith.Burton wrote:
Thanks for this, I am new to this so can you recommend some reputable suppliers please?
2024-06-22 12:36:21
2024-06-20 00:31:37
