Forum >Problem with sensors when switching on water recirculation pump
Hello, I have recently purchased the
"Gravity: Analog pH Sensor/Meter Kit V2 (Arduino & Raspberry Pi & micro:bit Compatible)" together with the module "Gravity: Analog TDS Sensor/ Meter for Arduino" and the isolator "Gravity: Analog Signal Isolator", Everything works perfect, I am very happy with the system until I plugged a fish tank motor to recirculate the water... then the pH dropped several tenths.... I unplug the motor and it stabilizes again...
What could be happening? How can I solve the problem?
Thank you very much...
ESP32 / ESP8266 ProjectsESP32 TutorialsESP8266 TutorialsESP32 / ESP8266 ProductsMore Gravity ProjectsView Gravity Products
