Forum >SSH Connections
UNIHIKERGeneral
SSH Connections
userHead John.Hugery 2024-06-25 18:23:30 1230 Views3 Replies
Greetings.  After connecting the Unihiker to WiFi, it no longer responds on the USB connection (10.1.2.3).  Is this normal?  What if I disconnect from Wifi?  Will the unit no longer be accessible?  Can I get both network interfaces to work simultaneously (eg SSH into either 10.1.2.3 or the Wifi IP Address)?
2024-08-11 14:13:46
Hello @lupin,
How did you enable your Wi-Fi? By default, I get the following:
root@unihiker:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
   link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   inet 127.0.0.1/8 scope host lo
      valid_lft forever preferred_lft forever
   inet6 ::1/128 scope host
2: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   link/ether 00:e0:4c:84:34:77 brd ff:ff:ff:ff:ff:ff
3: p2p0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   link/ether 02:e0:4c:84:34:77 brd ff:ff:ff:ff:ff:ff
4: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
   link/ether 00:e0:4c:9e:fe:c1 brd ff:ff:ff:ff:ff:ff
   inet6 fe80::2e0:4cff:fe9e:fec1/64 scope link
5: usb1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master br0 state DOWN group default qlen 1000
   link/ether 00:e0:4c:9e:fe:c3 brd ff:ff:ff:ff:ff:ff
6: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
   inet 10.1.2.3/24 brd 10.1.2.255 scope global br0
root@unihiker:~#
Don't mean to post a redundant question (because I just inquired about gateway address assignment) but what made UNIHIKER receive 10.0.0.14 for your Wi-Fi? Thanks.
Regards.
P.S.
I do have a dual band Wi-Fi Access point actively serving other clients in my farm.
userHeadPic Matha.Goram
Matha.Goram wrote:
Please disregard this message! In my haste, I did not visit the Network Settings page previously. I have done so now, and my Wi-Fi is up and running. Sorry for the false alarm. Thanks for your understanding.
Regards.
2024-08-11 14:20:09
2024-06-28 03:52:44
Both interfaces should work at the same time. I can confirm this with following output:
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
   link/ether b6:a8:05:81:5e:1c brd ff:ff:ff:ff:ff:ff
   inet 10.0.0.14/24 brd 10.0.0.255 scope global dynamic noprefixroute wlan0
      valid_lft 85446sec preferred_lft 85446sec
   inet6 fe80::95d4:4553:a9f7:b05e/64 scope link noprefixroute
   link/ether 00:e0:4c:28:9b:f9 brd ff:ff:ff:ff:ff:ff
   inet6 fe80::2e0:4cff:fe28:9bf9/64 scope link
In this case the unihiker is connected as station to an access point (#2) and I'm connected via SSH/USB (#6) …
userHeadPic Lupin
