Forum >SEN0395 mmWave + ESP32C3 error
Troubleshooting
userHead Ridwan.Anhar 2024-07-01 23:09:59 682 Views1 Replies
So im trying the mmWave sensor using this ESP32C3 Board. I injeced the example code from the library with modified RX TX pin (21,20).
#include <DFRobot_mmWave_Radar.h>
HardwareSerial mySerial(1);
DFRobot_mmWave_Radar sensor(&mySerial);
int ledPin = 13;
  Serial.begin(115200);
  mySerial.begin(115200, SERIAL_8N1, 21, 20);//RX,TX
  pinMode(ledPin, OUTPUT);
  sensor.factoryReset();    //Restore to the factory settings
  sensor.DetRangeCfg(0, 2);    //The detection range is as far as 9m
  sensor.OutputLatency(1, 2);
  int val = sensor.readPresenceDetection();
  digitalWrite(ledPin, val);
  Serial.println(val);
And this is what i got from the Serial Monitor
what happened and whats wrong with my coding?
2024-07-04 00:17:32
Have you pressed the RST button of the ESP32 after uploading the code?
userHeadPic lia.ifat
