Forum >TEL0124, antenna connector
General Arduino
userHead Gunnar 2024-07-09 12:23:02 693 Views5 Replies
I need to replace the antenna supplied with the TEL0124 board but I cannot find what is the type of connector on the board in the documentation. Can someone confirm that is is a U.FL connector?
Thanks in advance
2024-07-22 05:39:43
Thanks a lot for the replies. I could not find any clear information in the documentation so to be on the safe side I ordered adapter cables with MMCX as well as U.FL and I can confirm the connector on the board is U.FL.
userHeadPic Gunnar
2024-07-14 09:30:40
You can check the schematic here: https://wiki.dfrobot.com/SIM7600CE-T_4G(LTE)_Shield_V1.0_SKU_TEL0124#target_6
userHeadPic lia.ifat
