Forum >LATTE PANDA DELTA wifi connector on board broke
General LattePanda
userHead sean.farmar 2024-07-10 03:06:52 730 Views1 Replies
I tried to connect the wifi antenna to the port but in the process, broke the ring on the board… :-|
Any suggestions of how to fix this?
Can the wifi work with only one antenna? (right now, it works but with very high latency - around 400 ms)
Cheers,
Sean
2024-07-12 01:39:30
I don't think it is repairable. However, you can post to the lattepanda wifi forum.
userHeadPic lia.ifat
