Forum >ESP32 WROOM D Issue: Guru Meditation Error: Core 1 panic'ed (LoadProhibited).
I am using the DFRobot LIS2DW12 sensor to read accelerometer data using FireBeetle-ESP32 WROOM D. I am using the example code used in the DFRobot-LIS “getAcceleration”. Here is the issue I keep facing:
I have checked the operation of the sensor using Arduino-Uno, it works flawlessly but when i used a similar code on the ESP32 this error persists. Can anyone help me understand the issue?
