Forum >Combining keypad and 8 digit 7 segment display (SKU DFR0646\DFR0645)
ArduinoTroubleshooting
userHead Henrik.Larsen 2024-07-20 16:26:26 349 Views0 Replies
I am trying to write to the individual digits of the “8 digit 7 segment display”, but I am not able to do it based on an array (or other variables).
I am able to write both to the individual segments and send doubles into it, but I would like the input to come from an array.
So instead of:
LEDDisplaySegmentObject.print("1","2","3","4","5","6","7","8")
I would like the individual segments to come from an array (that have 8 values that comes from the keypad):
LEDDisplaySegmentObject.print(KeypadInputArray[0], KeypadInputArray[1], KeypadInputArray[2], KeypadInputArray[3], KeypadInputArray[4], KeypadInputArray[5], KeypadInputArray[6], KeypadInputArray[7]);
The reason why I would like to do it as sending to the individual digits, is because the remaining figures should be “blank”.
I think that the problem is because of the value comming from the keypad is “char” and then it instert it in the print-command of the segment display as 48, 49, 50 etc. instead of 0, 1, 2 etc.
Thanks in advance - I have tried for five hours and I am getting kind of frustated.
/Henrik
// Libraries
#include <Keypad.h>
#include "DFRobot_LedDisplayModule.h"
// Set Up KeypadObject
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {6, 11, 10, 8}; // Row pinouts of the keypad
byte colPins[COLS] = {7, 5, 9}; // Column pinouts of the keypad
// Create KeypadObject
Keypad KeypadObject = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Create LEDDisplaySegmentObject
DFRobot_LedDisplayModule LEDDisplaySegmentObject(&Wire, 0xE0);
// Create Variables
int KeypadInputNo = -1;
int KeypadInputArray[8] = {"","","","","4","","",""};
//// Setup
void setup(){
  Serial.begin(9600);
  /*Wait for the chip to be initialized completely, and then exit*/
  while(LEDDisplaySegmentObject.begin(LEDDisplaySegmentObject.e8Bit) != 0)
    Serial.println("Failed to initialize the chip , please confirm the chip connection!");
    delay(1000);
  //Set LEDDisplaySegmentObject Display Area
  LEDDisplaySegmentObject.setDisplayArea(1,2,3,4,5,6,7,8);
  //Clear LEDDisplaySegmentObject Display Area
  LEDDisplaySegmentObject.print("","","","","","","","");
  //Print "KLAR"
  Serial.println("<<<KLAR>>>");
//// Main Loop
void loop(){
  //Get CurrentKeyPress
  char CurrentKeyPress = KeypadObject.getKey();
  if (CurrentKeyPress){
    if ((CurrentKeyPress == 48) || (CurrentKeyPress == 49) || (CurrentKeyPress == 50) || (CurrentKeyPress == 51) || (CurrentKeyPress == 52) || (CurrentKeyPress == 53) || (CurrentKeyPress == 54) || (CurrentKeyPress == 55) || (CurrentKeyPress == 56) || (CurrentKeyPress == 57)){
      //Update KeypadInputNo
      KeypadInputNo = KeypadInputNo + 1;
      //Update KeypadInputArray
      KeypadInputArray[KeypadInputNo] = CurrentKeyPress;
      //Write Current Input To Serial Monitor
      Serial.print("No. ");
      Serial.print(KeypadInputNo);
      Serial.print(" - ");
      Serial.println(KeypadInputArray[KeypadInputNo]);
      //Update Display   LEDDisplaySegmentObject.print(KeypadInputArray[0],KeypadInputArray[1],KeypadInputArray[2],KeypadInputArray[3],KeypadInputArray[4],KeypadInputArray[5],KeypadInputArray[6],KeypadInputArray[7]);
      //Check For Correct Input If Last Digit
      if (KeypadInputNo == 7){
        CheckForCorrectInput(KeypadInputNo);
//// Check For Correct Input
void CheckForCorrectInput(int& KeypadInputNo){
  //Write Status To Serial Monitor
  Serial.println("TEST FULL INPUT");
  //Reset KeypadInputNo
  KeypadInputNo = -1;
  //Perform Code For Wrong Input
  InputIsWrong();
//// Input Is Correct
void InputIsCorrect(){
//// Input Is Wrong
void InputIsWrong(){
  //Make Display Flash For Two Seconds
  LEDDisplaySegmentObject.flashHalfs();
  delay(2000);
  LEDDisplaySegmentObject.stopFlash();
  //Reset Display
