Forum >Alternate sample code for FIT0441
Suggestions
userHead Richard.Sewell 2024-07-28 06:09:51 3166 Views1 Replies
I've just been getting a FIT0441 running on a Nano, and found the sample on the Wiki was not as helpful as it could be. Here's my current code in case it's useful.
#define DIRECTION_PIN 10
#define PWM_PIN 11
#define ENCODER_PIN 2  // must be an interrupt-capable pin, 2 is a good choice on a Nano
long pulsesPerRev = 45*6;  // gearbox is 45:1 reduction, motor has 6 pulses/rev
unsigned long directionChangeTime = 0;
bool direction = HIGH;
int rpmTarget = 100;
int encoderPulses = 0;
long lastEncoderTime = 0;
long encoderInterval = 1;
long encoderRPM = 0;
long lastPrintMillis = 0;
  // put your setup code here, to run once:
  Serial.begin(115200);
  TCCR2B = TCCR2B & 0b11111000 | 1; //set PWM frequency to 32khz, good for Nano and Uno
  pinMode(DIRECTION_PIN, OUTPUT); //direction control PIN 10 with direction wire
  pinMode(PWM_PIN, OUTPUT);
  digitalWrite(DIRECTION_PIN, direction);
  attachInterrupt(digitalPinToInterrupt(ENCODER_PIN), encoderISR, RISING ) ;
  if (millis() - directionChangeTime > 5000)  {
    direction = !direction;
    directionChangeTime = millis();
  if (Serial.available())  {
    int a = Serial.parseInt();
    if( a != 0 )
      rpmTarget = 255 - a;
      analogWrite(PWM_PIN, rpmTarget );  //input speed (must be int)
      delay(200);
  long now = millis();
  if( now-lastPrintMillis > 500 )
    Serial.print("  r/min, target is ");
    Serial.println(rpmTarget);
    Serial.print("Encoder interval ");
    Serial.println(encoderInterval);
    Serial.print("encoderPulses ");
    Serial.println(encoderPulses);
    Serial.print("totalRevs ");
    Serial.println(encoderPulses/pulsesPerRev);
    Serial.print("encoderRPM ");
    Serial.println(encoderRPM);
    lastPrintMillis = now;
  i = 0;
void encoderISR()
  if( direction )
    encoderPulses ++;
  else
    encoderPulses--;
  long now = micros();
  encoderInterval = now - lastEncoderTime;
  lastEncoderTime = now;
  encoderRPM = (60L * 1000000L) / (encoderInterval * pulsesPerRev);
2024-07-29 16:16:45
Thanks for sharing.
userHeadPic lia.ifat
