Forum >SER0061 minimum PWM control voltage
SER0061 45KG Torque Coreless Waterproof Servo -
Control System: PWMWorking Voltage: 6.0V ~8.4VWorking Temperature: -20℃~ +60℃
Does this mean SER0061 cannot be used in Arduino projects without external booster or should the control usually work with 5V PWM?
Thanks, from a noob
2024-07-29 00:18:29
Anttiry
Here's a link for the DFRobot Servo
https://www.dfrobot.com/product-2573.html
It says on the name it's Servo so I guess it can be used in servo mode, too. I wonder if that, too, is limited to 6V+ ?
