Forum >Beetle ESP32-C6
Beetle ESP32-C6
userHead Luc.Paquin 2024-08-01 09:35:26 964 Views2 Replies
I am using a Beetle ESP32-C6 and am trying to get some simple AnalogReadSerial using Arduino 1.8.19
Beetle ESP32-C6
// the setup routine runs once when you press reset:
 // initialize serial communication at 9600 bits per second:
 Serial.begin(9600);
// the loop routine runs over and over again forever:
 // read the input on analog pin 0:
 int sensorValue = analogRead(A3);
 // print out the value you read:
 Serial.println(sensorValue);
 delay(1);        // delay in between reads for stability
Arduino: 1.8.19 (Windows 10), Board: "DFRobot Beetle ESP32-C6, Disabled, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 160MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 115200, None, Disabled, Disabled"
G:\Documents\Devcoop\DonLuc\Blog\HomeBot\DL2402Mk04\AnalogReadSerial\AnalogReadSerial.ino: In function 'void loop()':
AnalogReadSerial:22:32: error: 'A3' was not declared in this scope
  22 |   int sensorValue = analogRead(A3);
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Beetle ESP32-C6
 Serial.begin(9600);
 int sensorValue = analogRead(4);
COM11
FireBeetle 2 ESP32-E
 Serial.begin(9600);
 int sensorValue = analogRead(A0);
COM3
10:52:33.530 -> 1677
10:52:38.531 -> 0
10:52:43.528 -> 0
10:52:48.522 -> 4095
10:52:53.518 -> 4095
10:52:58.513 -> 4095
10:53:03.515 -> 4095
10:53:08.507 -> 4095
10:53:13.507 -> 4095
10:53:18.519 -> 4095
10:53:23.510 -> 4095
Beetle ESP32-C6????
2024-08-02 08:40:45
Beetle ESP32 C6
FireBeetle 2 ESP32-C6
Arduino IDE menus
Tools > USB CDC On Boot > Enabled
ESP32 family with native USB capability is that they are typically configured to have their USB CDC serial port disabled by default.
userHeadPic Luc.Paquin
2024-08-02 08:12:50
Replace A3 with the correct pin number based on your board’s pin mapping. For the Beetle ESP32-C6, analog pins are typically mapped directly by their numbers rather than the A0, A1, etc., convention used in some Arduino boards.You can edit your code like this:
 Serial.begin(9600);
 // read the input on analog pin (e.g., GPIO 4, which might be the correct analog pin):
 int sensorValue = analogRead(4); // Change 4 to the correct pin number
 delay(100); // delay in between reads for stability
userHeadPic lia.ifat
