Forum >Connecting Two Gravity DACs to an Arduino Zero problem
General GravityArduino
userHead Ferg.Colto 2024-08-05 09:46:41 496 Views2 Replies
Hello!
I'm trying to connect two Gravity DAC 0-10V modules to an MKR Zero board.
On the Gravity boards, i have one address set to 0x58 and one set to 0x5F - So the pins are 000 and 111 respectively.
The two boards kind of work, sometimes. In testing I found that each individual board would work well when tested on its own - the output voltages were stable and accurate.
When i connect both boards, things go quite wrong. The code will upload, but then the Arduino will give Initialize Errors for the Gravity boards.
If i plug out the Arduino USB, and back in it will work, but the voltages are now higher than i requested. Sometimes the Arduino USB wont connect - Windows says there is a USB not recognised error.
Is this a power supply issue, or does anyone know how to solve this?
thank you!
2024-08-05 13:03:29
Make sure you have the correct drivers installed for the MKR Zero. Reinstalling the drivers might help with the USB connection issue.
userHeadPic lia.ifat
2024-08-05 09:59:59
for reference, here is my code :
#include "DFRobot_GP8403.h"
DFRobot_GP8403 dac(&Wire,0x58);
DFRobot_GP8403 dac2(&Wire,0x5F);
int StateMachine = 0;
// Interrupt Service Routine (ISR)
void changeState ()
 StateMachine++;
 if(StateMachine>4)
     StateMachine=9;
    Serial.print("Machine State = ");
    Serial.println(StateMachine);
void resetState ()
   Serial.println("reset");
 StateMachine=0;
 Serial.begin(115200);
 while(dac.begin()!=0){
   Serial.println("init error 1");
   delay(500);
   while(dac2.begin()!=0){
   Serial.println("init error 2");
   delay(500);
 Serial.println("init succeed");
 dac.setDACOutRange(dac.eOutputRange10V);//Set the output range as 0-10V
 dac2.setDACOutRange(dac2.eOutputRange10V);//Set the output range as 0-10V
 attachInterrupt(digitalPinToInterrupt(5), changeState, RISING);
 attachInterrupt(digitalPinToInterrupt(4), resetState, RISING);
void loop(){
switch (StateMachine) {
 case 1:
   dac.setDACOutVoltage(2000,0); // OUT0 channel 1
   dac.setDACOutVoltage(2000,1); // OUT1 channel 1
   dac2.setDACOutVoltage(2000,0); // OUT0 channel 2
   break;
 case 2:
   dac.setDACOutVoltage(4000,0); // OUT0 channel 1
   dac.setDACOutVoltage(4000,1); // OUT1 channel 1
   dac2.setDACOutVoltage(4000,0); // OUT0 channel 2
   break;
 default:
   dac.setDACOutVoltage(0,0); // OUT0 channel 1
   dac.setDACOutVoltage(0,1); // OUT1 channel 1
   dac2.setDACOutVoltage(0,0); // OUT0 channel 2
   break;
 dac.store();
 dac2.store();
userHeadPic Ferg.Colto
