Forum >How to use Unihiker with Linux I2C devices using Python
UNIHIKERGeneral
userHead Ralph.Yamamoto 2024-08-07 20:39:37 1220 Views1 Replies
I am trying to use Unihiker to connect to a Blues Notecard.  I would like to use the Blues note-python library which connects to the standard i2c devices in /dev.
If I run i2cdetect -l it returns
i2c-1   i2c             rk3x-i2c                                I2C adapter
i2c-2   i2c             rk3x-i2c                                I2C adapter
I can see both these devices in /dev.
crw-rw---- 1 root i2c      89,   1 Feb 14  2019 i2c-1
crw-rw---- 1 root i2c      89,   2 Feb 14  2019 i2c-2
Is there a way to use these devices on the Unihiker or is there an example of how to modify code that uses these devices?
For some reason I can't attach the code file even though it is only 3KB it complains about a max size of 10MB.
Here is anexcerpt from the code:
import notecard
from periphery import I2C
"""Connect to Notcard and run a transaction test."""
   print("Opening port...")
   try:
       port = I2C("/dev/i2c-1")
   except Exception as exception:
       raise Exception("error opening port: "
                       + NotecardExceptionInfo(exception))
   print("Opening Notecard...")
   try:
       card = notecard.OpenI2C(port, 0, 0, debug=True)
       raise Exception("error opening notecard: "
I don't get an error from “Opening port” but it occurs when "Opening Notecard"
root@unihiker:~/python_code/blues# python3 note-python_i2c.py
Opening port...
Opening Notecard...
Resetting Notecard I2C communications.
[Errno 6] I2C transfer: No such device or address
2024-08-08 08:31:55
from pinpong.board import Board, I2C
On documentation page (https://www.unihiker.com/wiki/system-framework) you will see that I2C is available via MCU. So in case of Python you should use the pinpong library.
userHeadPic Lupin
