Forum >UNIHIKER and OpenCV
General UNIHIKER
UNIHIKER and OpenCV
userHead Matha.Goram 2024-08-12 06:24:58 1139 Views0 Replies
Hello!
The basic Hello OpenCV exercise fails with the following message:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "/usr/local/lib/python3.7/dist-packages/cv2/qt/plugins" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb.
Aborted
The Python (3.7.1) script reads the image file correctly but cannot display it with the imshow function. The xcb library is installed as reported by apt:
libxcb1 is already the newest version (1.13.1-2).
libxcb1 set to manually installed.
The OpenCV version is 4.7.0
Is there any workaround for the anomaly? Thanks.
Regards.
