Forum >DFR Recommended Library for SQL Interface
General UNIHIKER
userHead Matha.Goram 2024-08-25 20:11:50 3819 Views0 Replies
Cannot install the MariaDB Python library:
  Downloading mariadb-1.1.6.tar.gz (83 kB)
    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 83.7/83.7 kB 1.1 MB/s eta 0:00:00
 Installing build dependencies ... done
 Getting requirements to build wheel ... error
 error: subprocess-exited-with-error
 × Getting requirements to build wheel did not run successfully.
 │ exit code: 2
 ╰─> [1 lines of output]
     MariaDB Connector/Python requires MariaDB Connector/C >= 3.3.1, found version 3.1.21
     [end of output]
The UNIHIKER OS repository does not provide the required version by default. Building the Connector from source may upset the apple cart (i.e. after all the OS is Buster). Is there a direct solution? Thanks.
Regards.
P.S.
Of course, there is a workaround, but that requires two extra hops!
