Forum >Voice recognition module SEN0539 connecting to Arduino Nano
General ArduinoGravity
userHead Mike.Shepherd 2024-08-27 07:33:06 393 Views0 Replies
Hi, I'm having real problems connecting this device to my Nano.
With the original programming
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266))  // Use software serial
SoftwareSerial softSerial(/*rx =*/4, /*tx =*/5);
DFRobot_DF2301Q_UART asr(/*softSerial =*/&softSerial);
#elif defined(ESP32)  // Use the hardware serial with remappable pin: Serial1
DFRobot_DF2301Q_UART asr(/*hardSerial =*/&Serial1, /*rx =*/D3, /*tx =*/D2);
#else                 // Use hardware serial: Serial1
DFRobot_DF2301Q_UART asr(/*hardSerial =*/&Serial1);
#endif
I get the error
C:\Users\xxxx\Documents\Arduino\Voice_Module\Voice_Module.ino:29:43: note: suggested alternative: 'Serial'
DFRobot_DF2301Q_UART asr(/*hardSerial =*/&Serial);
                                          Serial
exit status 1
Compilation error: 'Serial1' was not declared in this scope
I commented out each line except
And changed "Serial1" to "Serial"
That worked and the sketch uploaded ok - however on the serial monitor it constantly says
16:41:59.440 -> Begin ok!
16:41:59.440 -> ���������������������������_�
Even when the device isn't connected.
Something obviously isn't right - does anyone have working code and connection instructions for the Nano?  I've been searching for a few days now.
Many thanks,
Mike
