Forum >C1001 60GHz mmWave Indoor Fall Detection Sensor init error!!!
TroubleshootingArduino
userHead Dean.Huang 2024-08-30 20:20:33 1587 Views4 Replies
Here, I encountered an initialization error with the C1001 60GHz mmWave sensor when using it with the Arduino MKR WiFi 1010 and ESP-WROOM-32, the output and code in below.
serial monitor output:
init error!!!
Initialization successful
Start switching work mode
error!!!
error!!!
error!!!
error!!!
error!!!
Code:
* @file sleep.ino
* @brief This is an example of the C1001 mmWave Human Detection Sensor detecting the presence of people and their respiration and heart rates.
* @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @license     The MIT License (MIT)
* @author [tangjie](jie.tang@dfrobot.com)
* @version  V1.0
* @date  2024-06-03
* @url https://github.com/DFRobot/DFRobot_HumanDetection
#include "DFRobot_HumanDetection.h"
// Declare hu as a global variable so it's accessible in all functions
DFRobot_HumanDetection hu(&Serial1);
 Serial.begin(115200);
 // Begin Serial1 with TX = Pin 14, RX = Pin 13
 Serial1.begin(115200);
 Serial.println("Start initialization");
 // Attempt to initialize the sensor
 while (hu.begin() != 0) {
   Serial.println("init error!!!");
   delay(1000);
 Serial.println("Initialization successful");
 Serial.println("Start switching work mode");
 // Switch to sleep detection mode
 while (hu.configWorkMode(hu.eSleepMode) != 0) {
   Serial.println("error!!!");
   delay(1000);
 Serial.println("Work mode switch successful");
 Serial.print("Current work mode:");
 // Check and print the current work mode
 switch (hu.getWorkMode()) {
   case 1:
     Serial.println("Fall detection mode");
     break;
   case 2:
     Serial.println("Sleep detection mode");
     break;
   default:
     Serial.println("Read error");
 // Configure the LED and reset the sensor
 hu.configLEDLight(hu.eHPLed, 1);  // Set HP LED to ON
 hu.sensorRet();                   // Module reset
 Serial.print("HP LED status:");
 // Check and print the LED status
 switch (hu.getLEDLightState(hu.eHPLed)) {
   case 0:
     Serial.println("Off");
     break;
   case 1:
     Serial.println("On");
     break;
   default:
 Serial.println();
 Serial.println();
 Serial.print("Existing information:");
 // Check and print if someone is present
 switch (hu.smHumanData(hu.eHumanPresence)) {
   case 0:
     Serial.println("No one is present");
     break;
   case 1:
     Serial.println("Someone is present");
     break;
   default:
 Serial.print("Motion information:");
 // Check and print motion status
 switch (hu.smHumanData(hu.eHumanMovement)) {
   case 0:
     Serial.println("None");
     break;
   case 1:
     Serial.println("Still");
     break;
   case 2:
     Serial.println("Active");
     break;
   default:
 // Print body movement parameters, respiration rate, and heart rate using print and println
 Serial.print("Body movement parameters: ");
 Serial.println(hu.smHumanData(hu.eHumanMovingRange));
 Serial.print("Respiration rate: ");
 Serial.println(hu.getBreatheValue());
 Serial.print("Heart rate: ");
 Serial.println(hu.getHeartRate());
 Serial.println();
 delay(1000);
2024-09-05 12:36:17
The begin/init routine is rather simple, it reads a small amount of data off the serial port.  Since you are using an ESP32,
  #if defined(ESP32)
 Serial1.begin(115200, SERIAL_8N1, /*rx =*/D3, /*tx =*/D2);
 #else
 #endif
userHeadPic Jim.OQuinn
Jim.OQuinn wrote:
Hit Submit before I was done, since you are using an ESP32, why not include the additional port setup parameters for the begin() function?  I'm not sure what the defaults are for the ESP-WROOM-32's non-native UART pins.  Browsing the various project examples I find these additional parameters included in all of them.
*  https://wiki.dfrobot.com/SKU_SEN0623_C1001_mmWave_Human_Detection_Sensor#target_5
Also, the ESP-WROOM-32's native UART pins are GPIO16 and GPIO17, you could give them a try.
Lastly, are your RX and TX connected to the correct GPIOs on the ESP32?  Are they crossed or directly connected?
2024-09-05 13:03:47
2024-09-02 05:47:31
I had similar issues until I soldered the connections and made sure it had enough power and it works as expected now.
userHeadPic Michael.FitzGerald
2024-08-30 20:35:17
SKU:SEN0623
userHeadPic Dean.Huang
