Forum >Raw API use of Gravity Color Display (DFR0997)
General Gravity
userHead DougBrooklyn 2024-09-11 13:29:37 520 Views2 Replies
Hi Folks,
I would like to use the DFR0997 I2C/UART display with something that is not an Arduino or Microbit, for which libraries have been provided.
Is there a reference on how to communicate with it at the low level (UART/I2C) to make it display stuff please?
Also, it has a USB-C for firmware updates: where can I get the latest firmware please?
Thanks!
2024-09-15 06:59:26
Thank you for the prompt reply. I will be in touch. As there are no firmware updates, that's entirely fine that there are no instructions or firmware files available! Thanks.
userHeadPic DougBrooklyn
2024-09-11 21:37:56
The communication protocols are not publicly available, you can contact DFRobot technical support for a list of internal communication protocols.
As for firmware upgrades, we don't have a version 2 firmware available yet. Therefore, the firmware upgrade method is not disclosed for the time being. When the firmware is disclosed later, the corresponding description will be added on the wiki.
DFRobot techsupport:
techsupport@dfrobot.com
userHeadPic Yeez_B
