Forum >Firebeetle M0 blinking red led
Troubleshooting
userHead rob.colson 2024-09-25 22:53:11 429 Views1 Replies
I have picked up a fight with a firebeetle m0 dev board and I'm afraid it's winning.
So far I have
tried the example with the blinking built-in led tried to change the blinking to an external led on the breadboard interfaced the dfplayer through uart reverted to the built-in led blinking tried to interface a waveshare e-paper module through spi
At that point I encounter a problem: the arduino IDE does not see the COM port anymore. The red power led is blinking.
I unplugged everything, turned off the computer.
Then I plugged back only the usb-c cable and tried to program the built-in led blinking example. Same problem: COM port invisible and red power led blinking.
The COM port reset procedure does not seem to help.
What do you think of all this?
2024-09-26 08:12:46
update - I gave it another try: remove all peripheral connection, try to upload the led built in example. it works.
tried I to upload another rhythm in the blinking, it works as well.
I have no idea what I did different between this morning and this evening…
userHeadPic rob.colson
