Forum >SEN0366 and changing it's timing
userHead haslingen 2024-09-30 23:16:36 1135 Views3 Replies
How do I change the timing ot the sensor SEN0366?
I sent from the manual Time interval(1S): FA 04 05 01 FC. But what can I send if I want it to go back to the faster measurement it had from factory?
2024-11-24 05:06:24
Put 00 in the <rate> byte.
My new manual: https://drive.google.com/file/d/1l85iJBfYEdNifmljYyZ1gV7ogQPlVA-O/view?usp=drive_link
userHeadPic Digital Lives Matter
2024-11-16 23:36:55
The manual is pretty pathetic; however, the data rate command is FA 04 05 <rate> <cs>. I believe that the rate is expressed in either samples per second or the rate is 1/<rate>.
Issue the command with a few different <rate> values just to see what happens.
2024-11-15 22:59:27
I agree, would like to know how to do this as well.
userHeadPic Craig.Schaefer
