Forum >Voice Recognition Module
GravityTroubleshooting
userHead Mike.Harris 2024-10-06 15:11:44 1945 Views2 Replies
I’m having some trouble with my voice recognition module, and I could really use your help. I’ve followed the instructions to copy the code and connect the hardware, but I’m not getting the response I expect.
Here’s what I’ve observed:
When I say “hello robot,” the blue light on the module turns on, but there’s no other response from the system.I’ve attached the code I’m using, along with a photo of the microchip and the voice activation module for reference.
Could anyone help me troubleshoot this issue? What might I be doing wrong? Any advice or suggestions would be greatly appreciated!
2024-12-23 17:51:50
Check which side the SPK1 and SPK2 toggles are on, if you need on-board outputs to toggle the toggles to the SPK1 side.
userHeadPic yiqing.guan
2024-11-16 08:30:44
Is it possible you have the speaker switch set to use the external speaker port?
userHeadPic bradjshannon
