Forum >SEN0386 accelerometer non-zero X and Y static measurements
ArduinoTroubleshooting
userHead salva 2024-10-08 04:28:54 608 Views1 Replies
Hi, I´m currently trying to build a simple system with the SEN0386 sensor and an Arduino Uno Rev4 Wifi.
My issue is that, using the example code from the "DFRobot_WT62PC" library with a freq of 10Hz, and without moving the sensor, I always get an acceleration value of around 313, sometimes on X axis and sometimes on Y:
Acc      0.05       313.39   9.80
Gyro    0.00        0.00       0.00
Angle  358.92   0.28       331.06
Acc     313.60   313.42   9.80
Gyro   0.00        0.00       0.00
Angle 358.93    0.01      192.99
Z axis acceleration seems to work properly though.
Another issue I´ve found is that whenever I move the sensor, gyroscope values suddenly go up to around 4000:
Acc       313.59    313.43     9.81
Gyro    3999.76   3999.94   0.00
Angle  354.36     359.17      74.60
Acc     305.03     309.87   3.26
Gyro    3.60         11.72     3985.05
Angle  312.79     59.04    2.30
Maybe I don´t understand how the sensor configuration workd, but I can´t seem to find a way to work it out.
Here´s the code I´m using:
 * @brief Set the frequency of data output by the sensor, read the acceleration,
 * @n angular velocity, and angle of X, Y, and Z axes.
 * @n Experimental phenomenon: when the sensor starts, it outputs data at the set frequency and the data will be displayed on serial monitor.
 * @url https://github.com/DFRobot/DFRobot_WT61PC
#include <DFRobot_WT61PC.h>
#include <SoftwareSerial.h>
SoftwareSerial softSerial(/*rx =*/9, /*tx =*/10);
#define FPSerial softSerial
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266))   // Using a soft serial port
SoftwareSerial softSerial(/*rx =*/10, /*tx =*/11);
#else
#define FPSerial Serial1
#endif
DFRobot_WT61PC sensor(&FPSerial);
  //Use Serial as debugging serial port
  Serial.begin(115200);
  #if (defined ESP32)
    FPSerial.begin(9600, SERIAL_8N1, /*rx =*/D3, /*tx =*/D2);
  #else
    FPSerial.begin(9600);
  #endif
   * @brief Revise the data output frequncy of sensor
   * @param frequency - FREQUENCY_0_1HZ for 0.1Hz, FREQUENCY_0_5HZ for 0.5Hz, FREQUENCY_1HZ for 1Hz,
   * @n                 FREQUENCY_2HZ for 2Hz, FREQUENCY_5HZ for 5Hz, FREQUENCY_10HZ for 10Hz,
   * @n                 FREQUENCY_20HZ for 20Hz, FREQUENCY_50HZ for 50Hz, FREQUENCY_100HZ for 100Hz,
   * @n                 FREQUENCY_125HZ for 125Hz, FREQUENCY_200HZ for 200Hz.
  sensor.modifyFrequency(FREQUENCY_10HZ);
  if (sensor.available()) {
    Serial.print("Acc\t"); Serial.print(sensor.Acc.X); Serial.print("\t");
    Serial.print(sensor.Acc.Y); Serial.print("\t"); Serial.println(sensor.Acc.Z); //acceleration information of X,Y,Z
    Serial.print("Gyro\t"); Serial.print(sensor.Gyro.X); Serial.print("\t");
    Serial.print(sensor.Gyro.Y); Serial.print("\t"); Serial.println(sensor.Gyro.Z); //angular velocity information of X,Y,Z
    Serial.print("Angle\t"); Serial.print(sensor.Angle.X); Serial.print("\t");
    Serial.print(sensor.Angle.Y); Serial.print("\t"); Serial.println(sensor.Angle.Z); //angle information of X, Y, Z
    Serial.println();
2024-10-09 08:18:18
Solved by changing the function “getAcc()” in the library from:
Acc.X = ((int16_t)(buf[WT61PC_XH] << 8) | buf[WT61PC_XL]) / 32768.000 * 16.000 * 9.8;
To:
Acc.X = ((buf[WT61PC_XH] << 8) | buf[WT61PC_XL]) / 32768.000 * 16.000 * 9.8;
Same fix for the other two axes, and for “getGyro” and "getAngle".
userHeadPic salva
