Not working setNetMode & checkSignalQuality together
Dear DFROBOT Team,
I am facing a conflict between the checkSignalQuality() and setNetMode() functions in my project. When I use the checkSignalQuality() function before calling setNetMode(), the setNetMode() function fails to set the network mode and repeatedly returns "Fail to set mode". On the other hand, if I call setNetMode() first and then attempt to use checkSignalQuality(), the signal strength returns "404", indicating that it is unable to capture the signal strength.
Here is a simplified version of the code I am using:
int signalStrength;
Serial.println("Get signal quality......");
delay(1500);
signalStrength = sim7000.checkSignalQuality(); // Check signal quality
Serial.print("Signal strength = ");
Serial.println(signalStrength);
delay(500);
Serial.println("Set net mode......");
while (1) {
if (sim7000.setNetMode(sim7000.eGPRS)) { // Set GPRS mode
Serial.println("Set GPRS mode");
break;
} else {
Serial.println("Fail to set mode");
delay(1000);
Are there any known issues or conflicts between checkSignalQuality() and setNetMode() that might cause this behavior?
Do you have any suggestions or debugging tips for resolving this conflict?
