Forum >pH isolated measurements by Wifi
How to selectGravity
userHead Bubule 2024-10-14 22:04:32 1332 Views1 Replies
I need your help !
I have a project to transfer pH measurements via WiFi.
Because I have other probes in the same tank, I need total isolation between the probe and the Shelly Uni board (0-5V analog input).
I don't want an Arduino or other board behind the interface (apart from an isolation interface), because I have a distant Rpi server with Home Assistant inside.
I don't know which cards I need.
I imagine:
pH meter-Pro but which card. V1 or V2 ?  (I imagine preferring V1 than V2 because of better range (5V for V1 / 3V for V2)). 12V should be better because my Power supply, but… Am I reasoning correctly?
I don't understand what kind of signal is on the pH interface output. Is it linear analog (0/5V) or digital (I2c or other)?
Do I have to use a analog isolating board (DFR0504) or digital signal isolating board (DFR0565 ) ?
If it’s analog, I can connect directly to my Shelly-Uni analog input board. If it’s digital, what type of board should I take between isolating card and my Shelly-Uni ? ( DAC like DFR0552 ?)
Franck
2024-11-05 23:09:40
Can someone help me ?
Franck
userHeadPic Bubule
