Forum >Effect of temperature on SEN0189 turbidity sensor
userHead Account cancelled 2018-01-08 20:27:53 1619 Views1 Replies
I'm using this sensor in a project where the temperature of the liquid can vary and will be measured. I can see from a graph on the sensor wiki that this can change the output voltage by around 0.3 V. I was wondering if the data behind that graph, or similar data, can be posted as well? I'd like to incorporate it into my code to correct for temperature changes.
Thank you!
2018-01-11 00:57:17 The temperature do have affection on the turbidity, but it is not a big difference, you need to use precious sensor to detect the difference. userHeadPic robert.chen
