Forum >differential pressure sensor SEN0343 and Home Assistant
General Easy IoT
userHead FREDERIC.MONARD 2024-10-26 22:54:18 3935 Views1 Replies
I have reviewed the SEN0343 differential pressure sensor with interest for an HVAC control application. I would like to integrate it into Home Assistant via ESPHome and an ESP8266 or ESP32 module. Is this possible?
2024-10-30 21:25:55
Is it possible,  yes should you use a different sensor yes (XGZP6897D is natively supported). I have one running, you will need to add a custom component with your C++ code to pull data from the sensor.   Took me several days to get it up and running.
userHeadPic JeremiahJeremiah
