Forum >Ultrasonic Sensor Recommendation for Measuring Bin Level
How to select
userHead rrv 2024-10-28 20:58:26 1128 Views0 Replies
Hello
I am currently working on a project that involves measuring the fill level of a waste bin with the following dimensions: 1360 mm (H) x 1465 mm (W) x 1100 mm (D). I am interested in utilizing an ultrasonic sensor for this purpose and would appreciate your recommendations.
Could you please advise on which ultrasonic sensor would be best suited for measuring the fill level in a container of this size? Specifically, I am looking for a sensor that can provide accurate readings and is capable of handling the environmental conditions typical of waste management applications.
Thank you
