Forum >Can't connect via USB
TroubleshootingGravity
userHead IkeaGen 2024-10-31 17:14:06 377 Views3 Replies
Hello, when I connect the logger via USB, it gives me this error: The request could not be performed because of an I/O device error. When I connect the SD card on its own, it's empty. This is after following the steps of first start several times.
2024-11-25 21:06:47
I had a similar problem, but the USB port itself did not work correctly
userHeadPic Disha.Oberoi
2024-10-31 23:18:58
If you're able to access the SD card on your computer, try running a check for file system errors. On Windows, you can right-click on the SD card in "This PC," select "Properties," then go to the "Tools" tab and click on "Check" under Error Checking.
userHeadPic lia.ifat
