Forum >Ultrasonic Ranging sensor (SKU:SEN0591) not sending back data
TroubleshootingArduino
userHead David.Guidry 2024-11-05 08:49:19 370 Views0 Replies
I'm using the ultrasonic ranging sensor (3m) (SKU:SEN0591) for a project currently. After setting everything up per the directions, burning the sample code given, and setting baud rate to 115200 this is the only thing written to the serial monitor. I have tried to intercept the raw data before it goes through the CNC test, but the sensor seems to not be sending data back whatsoever.
link to sensor: https://wiki.dfrobot.com/Ultrasonic_Ranging_Sensor_3m_SKU_SEN0591
Serial monitor only comes back with "▯▯▯▯▯⸮6" when the code sends the COM array to the sensor
