Forum >I want to use object recognition but the builtin Led on the huskylens does not turn blue
General HUSKYLENS
userHead Jhon.EE 2024-11-10 09:35:58 1713 Views2 Replies
So I am working with a Huskylens right now and Im trying to use it for aiming with my turret. I want to use object recognition but the builtin Led on the huskylens does not turn blue, I want to do this because then I can work less on the aiming and just do keep turning left or right until blue led turns on, is there a possible way to do that and send the data of the LED turned on.
2024-12-19 17:39:27
It sounds like you're working with the HuskyLens object recognition module and encountering an issue where the built-in LED doesn't turn blue, which typically indicates the device is in object recognition mode. Here are some steps you can follow to troubleshoot this issue:
1. Check the Mode
Ensure that the HuskyLens is in Object Recognition Mode. The LED will only turn blue when the device is in this mode.Press the button on the HuskyLens to cycle through the modes (Object Recognition, Face Recognition, etc.), and ensure you're in the correct one.
2. Connection Check
Ensure the HuskyLens is properly connected to your microcontroller or device (like Arduino or Raspberry Pi). If it’s not receiving power or data, the LED might not light up as expected.
3. Firmware Update
Check if the firmware on the HuskyLens is up-to-date. Outdated firmware might cause certain functions to not work as expected. You can update it via the HuskyLens software.
userHeadPic Waqas.Tech
2024-12-17 10:04:37
HuskyLens can recognize 20 built-in objects. They are aeroplane, bicycle, bird, boat, bottle, bus, car, cat, chair, cow, dining-able, dog, horse, motorbike, person, potted lant, sheep, sofa, train, TV.
userHeadPic yiqing.guan
