Forum >MiCS-4514 sensor _ power supply
General Raspberry Pi
userHead Julien.Moreau 2024-11-13 01:12:40 637 Views1 Replies
I would like to power the MiCS-4514 sensor with a Raspberry pi. In the doc it is indicated that you can wire it with 3.3V but it is written in all the drawings that it can only be in 5V.
Also it is not explained what to do with the 4th port (EN). If I connect the latest on a GPIO, I assume that I need to specify which one somewhere? However I didn't find where in the provided example scripts
Thanks for your help
2024-11-15 18:46:32
Could you check if you write the wrong part number ?
The MICS-4514 can indeed be powered from 3.3~5v and does not have an EN pin
https://wiki.dfrobot.com/_SKU_SEN0377_Gravity__MEMS_Gas_Sensor_CO__Alcohol__NO2___NH3___I2C___MiCS_4514#target_0
I'm guessing you're using the MICS-5524, which is really only 5V powered, and the EN pin is described in the documentation.
https://wiki.dfrobot.com/Fermion__MEMS_Gas_Sensor___MiCS-5524_SKU_SEN0440
userHeadPic Yeez_B
