Forum >Is it possible to use RainbowLink 4 in GNU/Linux?
userHead fmilano 2024-11-17 00:00:58 594 Views1 Replies
Hi. I would like to buy a RainbowLink 4 but before that I want to check if it works in GNU/Linux, since I see only drivers for Windows and MacOS.
Does anybody know if this will work in a relative modern popular GNU/Linux distribution?
Kind regards,
Federico
2024-11-21 09:23:18
As long as you have the CH340 driver installed in your Linux, you can use the Rainbow link.
And the CH340 driver is installed by default in most modern GUN/Linux.
If not you can download the Linux CH340 Driver (but I’d recommend just upgrading your Linux kernel so that you get the  “built in” one).
CH340 driver on Linux:
https://github.com/DecaturMakers/CH340_drivers-Linux-Mac-Windows
userHeadPic Yeez_B
