Forum >problems with: Gravity: TCS34725 RGB Color Sensor
TroubleshootingGravity
userHead iksiazek 2024-11-24 02:03:48 163 Views1 Replies
1) There is a problem with compilation of the code because the function declared as static
 powf
is in conflict with such function declared as  extern in 'math.h'.
 2) There seems to be no possibility to switch off the white diodes by software.
2024-11-25 17:30:07
1. I have not encountered compilation problems in this environment.
May I ask what environment you are compiling in?
2. Yes, these diodes are directly powered to emit light.
userHeadPic Yeez_B
